How does the microphone seal work?
What kind of material is used for the microphone membrane? And how is it fixed on the microphone? Due to what water does not get there?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'm not sure on the material, but from what i remember from the design announcement, water does get in, but it is an enclosed unit so water doesn't go into the rest of the device. When you finish a workout, swim or water sport, you simply select the menu option to eject the water. That causes the microphone to vibrate at a very high speed, which ejects the water in the slot.
このアンサーは役に立ちましたか?
I thought such a system of dynamics. Or is the microphone made the same way?
Are you having a problem with the microphone?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 180
