メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150回答 すべてを表示
締切られた回答
Why wont my car start?
I was driving on the highway when my car stopped. before my car quit I was having long crank times. At the time my car stopped i was pushing the gas but it wouldnt accelerate. Then it finally died out. Now it just keeps turning over but wont start. My trunk also pops when I turn the key over. What could be the problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I would check fuel delivery---fuel pump/filter and make sure the lines are clear and you are receiving fuel at the engine. Another possibility would be the catalytic converter. You can test this by temporarily disconnecting it and seeing if your vehicle starts and runs but I would check out the fuel system first.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
+ sounds absolutely reasonable. First ? Do i get fuel? Second ? Do I have spark?
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,510
