メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
212回答 すべてを表示
Sensor error Tp2H, heatpipe, power supply
Hey all,
I've got an iMac late 2012 and to date it worked without any problems.
But after having updated to High Sierra, more and more problems appeared.
The system became slower and unresponsive. Today it reached the climax.
The screen turned black several times in a row, as if it would hibernate.
I started the Apple Hardware Test and it gave me this:
4SNS/1 /40000000 Tp2H-127.875
This means, that the powery supply / heatpipe reached a level of 127°C.
But I'm pretty sure that the sensor is just broken. I bet the system would blow up, if the temperature was real.
Now the question is, can this be easily fixed or does that mean the whole LogicBoard needs to be replaced? And is this worth it ($$$)?
Cheers,
Stephan
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@stevie_
Sensor
Tp2h
Description
AC/DC T2 Sec heatsink temp
Part Location
Built into power supply
Suggested Action
Check power supply cable connections to logic board; test with known-good logic board; test with known-good power supply. Check for clogged fans and/or vents; check cable connections to logic board.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Well that sounds (worst case) like either the Logicboard or the Power Supply needs to be replaced.
Does anyone know what such a repair will cost?
さんによる
Here's the IFIXIT power supply: iMac Intel 21.5" (Late 2012-2019) Power Supply as the sensor is on the power supply you have a good chance thats the likely part that will need to be replaced.
さんによる
Very cool, thanks! Didn't know that the sensor is located on the PSU itself.
さんによる
コメントを追加
回答を追加する
Stephan Römer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 789
