メインコンテンツにスキップ
This Samsung Tablet was first released in May 2015 and can be identified by its 9.7 inch diagonal screen. The model number of the device is “SM - T550.”
45回答 すべてを表示
(samsung t 555 ) Cant switch on tablet olso if battery is charged
I have a Samsung tab SM -555.The battery is still good but sometimes (a few times) I found it switched off and I dont know why (olso if I think the problem maybe can be the mini usb.One time after switching off the tab wont witch back on but afer "mooving something in the mini usb " I was able to power on again and use it (before I was able to power n the tablet only if the tab was connected at the charging cable). I think that it can be a false contact in the mini usb.Who can tel me the the order and functions of the various pins in the tab t555 mini usb?
Thank's
Claudia
ps: atm the tablet is working fine but maybe today,maybe tomorrow recharging it I will get back the same trouble :/
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Check the charging port for debris and use something like a toothpick to clean it out. Shining a flashlight into the power will make it easier to see if it's physically damaged or blocked.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@benjamen50 yes I have used a toothpick + can of compressed air and olso a spray clean contacts and after using a toothpick I was able to sorti it put (by the way are three days I use tha tab without any problem so I think s clean now.I neade to know witch pin is the one for the charge (or maybe is not a pin).Have u got any tip?
Thank's
Claudia
さんによる
コメントを追加
回答を追加する
claudiasandersbis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 108
