メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
531の回答 すべてを表示
rMacBook Pro 13, late 2013 slow after battery went to "replace now"
Hello,
I am using late 2013 Macbook Pro Retina 13, 2.6 GHz, i5, 8gb ddr, Intel Iris 1536mb, 512 SSD, running on macOS High Sierra 10.13.6 (the latest).
The cycles of my battery are 980. And up until now the battery condition was "service battery". It lasted for couple of hours without being plugged in. But yesterday the condition went to "replace now". After that my laptop became unbearably slow. Apps load slowly, when writing text appears after couple of seconds, tabs in safary take a lot time to load. Booting takes a lot time too.
I don't mind using my laptop only plugged in for now. I've read that "replace now" battery condition could slow down the laptop. Is there a way to dismiss this with software, so that it's fast again? I have tried SMC reset (although I am not sure it worked, because the lamp of the charger didn't change.)
I am unable to change my battery now, because I need my laptop for work. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sorry your MacBook is suffering!
You need to replace the battery there is no way around this via software. Order the IFIXIT kit here: MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery and follow this guide: MacBook Pro 13インチ Retina Display Late 2013 のバッテリーの交換 at most your down for a few hours. If you don’t have the skills to do this then its best to get to an Apple Store or authorized Apple service shop. Thy may take a few days.
MacBook Pro 13" Retina (Late 2013-Mid 2014) Batteryの画像
製品
$99.99
この回答は役に立ちましたか?
スコア 1
コメント:
Thanks, should I do something before following the guide?
さんによる
Get a good nights sleep, take your time and remember to breathe ;-}
さんによる
コメントを追加
回答を追加する
Kristian さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 331
