メインコンテンツにスキップ
イギリスとアメリカ以外のマーケット用に製造されたSonyのFEシリーズのラップトップです。
1回答 すべてを表示
Up to what cpu can I upgrade? (VAIO VGN-FE31b/w)
Hi.
I am using very old SONY VAIO VGN-FE31B/W, which I bought in Japan over 10 years ago. And I installed Bodhi linux. It goes so well till now.
Anyway, I don't like the cpu of it; Intel Celeron(R) M 430 1.7Ghz.
I upgraded most parts of this laptop, and lastly, I hope to be able to upgrade the cpu.
Is there Anybody who could tell me up to what kind of cpu I can upgrade it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Sadly the CPU is soldered to the logic board which is common in laptops. You would need to replace the full logic board to the best that Sony offered in this series which is likely more expensive than just buying a new system.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Not exactly. The CPU in sony vgn fe31b/w is not soldered at all.
さんによる
コメントを追加
Hi @hbmg as usual, if you have any important data, please backup first.
What I will suggest you to do is to try updating your laptop to the latest bios possible.
to really support, it really depends on the bios, what i do is normally i will compare the specs of what it can the laptop mainboard can support the processor, e.g.
listed on the website of the configuration,
https://www.cnet.com/products/sony-vaio-...
http://www.computer-specifications.com/s...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 549
