iPhone 6 came in with No Service/Line Searching issue
Hye i got an IP6 came in to me with No Service/Line Searching issue.. It showing the IMEI Number and Modem Firmware on settings, but when dialing *#06# not showing any IMEI. I try one of these solution and the issue is SOLVED, but after I restart/Switch Off the issue is COMING BACK..
The solution that i tried is..
1. Change Charging Port
2. Change Battery
3. Restore via iTunes
This 3 step is not solving the issue, after a few minutes the problem still same :(
I see a bunch of videos on Youtube and they said need to reball the Baseband CPU and make a jumper on U1 & V1. But my question is, how do I know if the BB_CPU is the main problem? Which line do I need to checked first ?
この質問は役に立ちましたか?
