メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The LG G Pad Tablet 7.0 was released in 2014, it is an Android based produced by LG. This device is the first produced tablet with a 7 inch screen and a 1.2 GHz Quad-core processor. Model number LG-V400.
My Tablet Won't Charge!
I have tried over 8 charging cords and it won't charge, If this helps, all of the cords feel very loose when plugged into my tablet and they pull out easily. Also If it does tell me it is charging, a couple minutes later it tells me it has stopped charging because it doesn't recognise the cord. They are all the right cords because they fit the port on it. Any answers are much appreciated!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@bunnybunny
“cords feel very loose when plugged in “ pretty good indication that your port is the actual issue. Take a look at this guide LG G Pad 7.0 Motherboard Replacement The charging port is mounted on it’s own flex cable. Replacing that with something like this should fix that.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jacob さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 40
今までの合計 436
