something stuck in sim card slot
there seems to be something stuck in my iphone 6s+ sim card slot because the tray will no longer go in. how do i disassemble the iphone to clear whatever is stuck in slot?
Yikes! Sounds like you have a problem! Depending on the size of the object there are 3 possibility's...
1. Your SIM slot is damaged and you probably should see an Apple pro about it.
2. The object has been lodged in the SIM slot.
3. The piece is a protector of the SIM slot.
The most likely of possible things is #2. Your iPhone may have a broken or damaged SIM slot. Hope my answer helped at all!!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 960
