The iPhone 6S is particularly sensitive to leaving the battery connected. Generally speaking, it's the backlight circuit that blows on the board. To test this, connect your phone to an iTunes enabled computer. The computer should recognize your phone (which means it is booting up). Then shine a bright light on the screen. If you see a dim image, then the backlight circuit is damaged.
This can be repaired but it requires a micro-soldering repair and is not really a DIY repair.
As for repair, look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. There are many shops worldwide that do this so you shouldn't have any problems finding them. Talk to them and ask how they do their work and good practices like proper cleaning of boards once completed etc.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum. You can also click on my profile to learn more about my services, at the very least, it can serve as a data point.
1件のコメント
Yikes! I once had a charger of that size that when I took it out of my phone it went up in FLAMES. I guess your lucky!
Genevieve Ezzell さんによる
