メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Skullcandy Crusherは、Sensation 55™とREX40™という2つのドライバーを搭載しており、優れた音質と体感できる重低音を実現します。2013年3月20日に発売され、モデル番号はS6SCFZ-072です。
Left side won't play any audio
So I've put the batterty in and all that fun stuff, I've even replaced the battery a couple of time and none of them seem to work so I was wondering how I could fix the audio only coming out of the right side
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
that's a pretty easy thing to diagnose. id say 9/10 times its a disconnect in the audio wire.
The labor, on the other hand, is usually extensive.
-Youll need to open the device, and disassemble the device nearly all the way.
-Start by verifying no cold joints on the soldering points of the speakers, and connecting wires. apply fresh solder to all joints, and test.
-Check the continuity on the wire going through the band. if thats not connecting properly, replace that wire.
-Verify speaker function. Put a low voltage, mid-frequency signal into the speaker to verify sound output. if it doesn't buzz, you will likely have to replace the speaker.
usually, it is one of the above that cause the issue, however, it is possible to have a board level failure.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Sadly I don't have access to soldering kits at this time,do you happen to know of a store I can take it to get it fixed?
さんによる 共有
that would be dependent on each city. you will need to take it to a repair shop. these shops are usually privately owned, so each town will have their own stores.
a quick local search for electronics repair may help.
さんによる 共有
Many thanks Scott
さんによる 共有
I am having a similar problem to this person. Although when i turn my headphones on and when they connect, I can hear the voice on both sides. I can only hear one side when i play anything.
さんによる 共有
I have this problem with the right speaker, a friend told me he dropped it causing the right side to completely stop working. I've played music through them and found that although both speakers vibrate, the right one does not play any of the music. I've struggled trying to find the speaker model number so I could replace it, where could I find these speakers?
さんによる 共有
1以上のコメントを表示
コメントを追加
回答を追加する
Griffin Perry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 43
今までの合計 4,148
