メインコンテンツにスキップ
Device repair and troubleshooting for the Dell Inspiron 15 inch laptop computer with model number 3567.
13回答 すべてを表示
How do I change the HDD on my Inspiron 15 3567 to an SSD?
I want to change the 5400 rpm 1 TB HDD on my laptop to an SSD.
The official manuals aren't very detailed and don't say if you can or can't.
Though websites like crucial.com say I can.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Laptops use a 2.5” SATA drive so replacing the HDD for a SSD only requires a drive swap out with another 2.5” SSD. The bigger issue will be installing a fresh copy of the OS and migrating your apps and stuff over.
Don’t forget you want to save some of the drives space for caching and paging file space. I would leave 1/3 to 1/4 of the space free for this.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Its easy,
1) Make sure you have a Bootable Windows 10 Pendrive, if not the make one, its easy, youtube has many videos on it.
2) Just buy any 2.5 SSD and replace it with the existing HDD.
3) Insert the Bootable Pendrive and boot the laptop and follow on screen instructions and instal Windows 10.
ALL DONE
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I am currently doing it (Dell 15” Inspiron 3567 i3 7th gen):
Difficulty depends on your experience with cloning drives and mechanical disassembly of electronics.
Considerations:
-In order to do it, you will need to disassemble the computer, at this point if you have considered a RAM upgrade I would do it at the same time (I am installing matching 16GB modules for a total of 32 GB of RAM)
-Today, SSD prices are much lower than in the past, making buying an equal size or larger SSD hard drive much more financially accessible. Most free cloning software (including that is part of Windows 10) require the target (SSD) drive to be the same size or larger. If you have an SSD that falls within this constraint just about any freeware program will allow you to clone the drive prior to disassembly. Once cloned, the drive should be tested by booting the system to the drive while plugged into the USB. You will need a 2.5” sata enclosure that can connect to the laptop (i.e. via USB).
-If your SSD is smaller than the drive currently installed in the laptop. A program called “DiskGenius” will allow you to clone to a smaller drive (This is what I did). I tried a few other “free programs” and am used to Mac OS environments where my skills in terminal allow me to clone drives without the need for additional software. I am not sure if that is a real option in Windows 10.
There are a number of tutorials on cloning the drive with DiskGenius. I found that in order to successfully clone the drive with that software I needed to do the following:
-Connect the drive
-Choose Clone from the drop down menu, choose the source and target drives
-Click on the “bootable/OS” partition on the drive map for the target (SSD) drive and right click, make sure “Keep Size” is checked (ignore the other partition sizes of the target volume)
-I attempted the “Hot Clone” multiple times and it failed every time. Allow “DiskGenius” to restart WinPE and clone the drive (~75 GB of real data/OS/Programs took ~1 hour to transfer). Do not choose to “Migrate” the OS, this also resulted in failure. The WinPE “Clone” booted perfectly.
-Once the clone is complete. Reboot the system with the SSD still connected to the USB and press F12 (I tapped f12 repeatedly) while booting. This will take you to a BIOS/Boot menu. The USB source should be in the list of available sources.
-If it is not, reset the BIOS options to factory settings and try again (this is what I needed to do).
Hope this helps, I know it took me a few hours to figure out how to approach it and a few more to figure out how to execute and succeed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kairy Nguyen Le さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 26
今までの合計 2,294
