black screen after power outage
restart after power outage audio only and black screen . after restart again no audio and black screen
how to fix
この質問は役に立ちましたか?
how to fix
この質問は役に立ちましたか?
Start by doing an electro static discharge . Unplug the TV so it has no power then hold your power button down for 60 seconds . Use the power button on the TV not on the remote. Then plug the TV back in and start it . If this brings no Joy try a reset . This should help with that
https://factory-reset.com/wiki/LG_Servic...
Hope this helps
このアンサーは役に立ちましたか?
sometime just changing channels will help
Open the back casing and look for a fuse on the power supply, or for burn marks on the display board.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 20
過去 30 日: 122
今までの合計 18,766
