Can my iPhone 5 still be updated to 10.3.3
I forgot to update my iPhone 5 to 10.3.3 if I asked my uncle to update it instead of restoring it will my data still be on there, is the update still available
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Upgrading your iOS shouldn’t loose your data. In any case you should always backup your phone or any computer! Just in case your phone sprout legs and runs off ;-}
How about just backing it up to the iCloud? You have 5 GB free! More than enough to save your phones contents. That way you’re sure not to loose anything.
このアンサーは役に立ちましたか?
@danj is the 10.3.3 update still available
10.3.3 is the current release if you update via Apple directly from your phone for iPhone 5 and is the last release for iPhone 5 phones (nothing newer will install as your phones ID will tell the Apple server what is needed).
Otherwise you'll need a PC or Mac to download the file from the Apple's iOS download page
You can't restore your iPhone 5 to iOs 8 since that iOs version is not signed by Apple anymore. You'll have to settle for iOs 10.
このアンサーは役に立ちましたか?
How can I update my iPhone 5 to iOS 10 without it turning on plus will my data still be on there if it’s updated
Only way to try to restore it is through a computer. You'll have to have iTunes installed..once you plug in the iPhone iTunes will guide you through the restore process. A full restore, if successful, will bring the phone back to the default state and your data will be lost unless you have an active iCloud backup or a previous local backup on the pc.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 430
