メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
MacBook Pro is not BOOTING using ALT and/or to Recovery Mode
I have a MBP 2011 from a customer and I am trying to reinstall the system however trying to use ALT to select the PEN DRIVE with macOS installation is not working. The CMD + R is not working too.
I already tried reseting the SMC and it didn´t help at all. However I tried resetting PRAM and it doesnt work out.
What can I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You mean Option Key don’t you?
Reference: Mac startup key combinations
Command + ‘‘R’’ may not work if the drive is not prepped (new drive). The newer firmware will automatically jump to internet recovery when you press Command + ‘‘R’’ so you will need a network connection to the internet via Ethernet or WiFi.
Did you replace the HD SATA cable yet? This is a common issue in this series.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes I mean ALT/OPTION.
I installed new drive tons of times and NEVER "prepped" the new drive. What should I do if OPTION and CMD+R both are not working?
I didn´t replaced the HD SATA. However I think this is not the case. Cause it came with a QUESTION MARK problem. and I just plugged the new HDD and it instantly showed the Apple Logo, however didnt go through the installation as I said earlier.
Att.
さんによる
Does it boot up with an external drive when you've disconnected the internal?
さんによる
コメントを追加
回答を追加する
Angelo Recaman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 265
