Issue with display or GPU?
Hello
can you please help to identify what is causing this issue - faulty GPU or display?
https://www.youtube.com/watch?v=5mc5Xd8c...
Thanks,
Gytis
この質問は役に立ちましたか?
Hello
Thanks,
Gytis
この質問は役に立ちましたか?
I’m thinking its more likely an internal display issue. To prove it you’ll need to connect to an external monitor to see if the problem shows up there if it doesn’t then the either the display cable or display assembly will need to be replaced.
このアンサーは役に立ちましたか?
I have connected external display and it works perfectly, hence I have ordered a new display cable. I have also noticed that the screen gets worse after opening/closing display lid, so I hope that changing display cable would address this. Thanks.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 64
