メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Battery indicator is incorrect
Battery indicator is incorrect, shows 1% for ages but will work for ages after this but screen is hard to see as automatically goes to dark. Probably at about 50 % but shows 1% . Don't want to do a factory reset any other suggestions
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
thanks i will try this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
The battery probably needs to be replaced, if that doesn't help then it's a board level issue that I don't think is worth repairing.
Battery is fairly cheap to replace.
Samsung Galaxy Tab 3 7.0 Battery Replacement
The screen flickering occurs when there is a critically low amount of charge on the battery so the battery is actually close to flat.
Replace a dead or damaged battery for your Galaxy Tab 3 7.0 Wi-Fi tablet with this part and fix issues with battery life. This is a used, OEM battery.の画像
製品
$17.99
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Michelle Green さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 1,470
