メインコンテンツにスキップ
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
28回答 すべてを表示
PC booting up but screen dark following screen replacement
I have recently replaced the laptop screen as the old one was cracked, when I put the new one in and powered up the machine the screen was extremely dark and the login screen was only visible when shining a torch at the display. I have tried plugging into an external monitor and that works fine. Does anyone know a solution for this or any additional troubleshooting that I can do? Thank you in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
It seems that you have "lost" the backlight power to the screen (assuming that the new screen is the correct one for your particular model laptop (what is the exact model number?) and if it is the correct one if it is OK and not faulty.
(You did have the battery removed from the laptop when you removed/replaced the screen didn’t you?)
Can you try the old screen again to check?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jack Yates さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 110
