メインコンテンツにスキップ
The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24回答 すべてを表示
life expectancy of each battery
My cellphone just switched off on its own and wont respond even when i try to put a charger on,it looks as if the is no battery at all .Im now wondering if this has anything to do with the battery at all because i've had this Blackberry Classic since 2014 and i've never changed or touched its battery,is it dead just like that without warning orcan i change the battery?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Battery's are typical only good for a couple years then they really start to show there age. If the phone is doing nothing while plugged in it could be a board issue though. If the battery is easy to change that would be the first and easiest thing to do. If that doesn't work its time for a new phone.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
swmcitakali さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 244
