メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
MagSafe connector not charging or supplying any power.
I was using my macbook last night just fine however I returned back from work today to find it won’t charge or take power. The battery and the system is still Operative for now. I had my book sitting on AC vent unit not sure if realveant however I have tried SMC reset a few times and
another MagSafe connector neither worked. I also cleaned out the port for any possible debris
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Are you getting a green/orange light on your charger or is there no light at all?
さんによる
No lights at all, however the battery is still functioning
さんによる
Unfotunatly it’s most likely your charging circuit, in most cases the chip isl6259 has been damaged. I would sent you macbook to a place that does microsoldering to troubleshoot the issue.
さんによる
コメントを追加
2件の回答
ベストアンサー
After further investigation I determined the fuse that connects to the the MagSafe port on the MacBook has been fried. However no other noticble damage on the logic board was discovered and the part is easily replaceable.
So all in all not that bad of damage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try using a different charger since that could be the problem. It might be a battery issue but that isn't likely. If these suggestions don't work then I would try taking it to Apple, and seeing what they say.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have tried another charger nothing happend it’s odd to me though that the battery is kicking out power but the MagSafe has no reading once so ever. I figure something fried on the logic board that has to do with power system because nothing else is registering as problematic to me
さんによる
コメントを追加
回答を追加する
Brenton さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 221
