MagSafe connector not charging or supplying any power.
I was using my macbook last night just fine however I returned back from work today to find it won’t charge or take power. The battery and the system is still Operative for now. I had my book sitting on AC vent unit not sure if realveant however I have tried SMC reset a few times and
another MagSafe connector neither worked. I also cleaned out the port for any possible debris
この質問は役に立ちましたか?
3 件のコメント
Are you getting a green/orange light on your charger or is there no light at all?
Anthony さんによる
No lights at all, however the battery is still functioning
Brenton さんによる
Unfotunatly it’s most likely your charging circuit, in most cases the chip isl6259 has been damaged. I would sent you macbook to a place that does microsoldering to troubleshoot the issue.
Anthony さんによる
