メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
2 completely dead iPhone 6s plus devices
I obtained 2 completely dead iPhone 6s plus devices. They do not charge or are recognized by iTunes (with or without battery connected to the motherboard). They do not warm up. I currently do not have an ammeter, but I used a battery pack that automatically detects devices. These are not detected. I suspect that both devices have a bad U2 IC, but I'm not sure of that. I already ordered a new battery and dock connector. But these are still on their way. I ordered these just to be sure.
Will the device boot with a new charged battery if the U2 IC (normally only for charging and USB connectivity) is dead? Or are there any more steps I can perform?
Thanks in advance.
Kind regards, Stefan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
iPhones do bootup with charged batteries that have a bad Tristar (U2) charging IC.
Some things to note:
If you can't get an apple logo with battery unplugged the Tristar is bad provided you can turn the phone on with a charged battery.
Once you get the phone on you can also try plugging the phone to a computer to see if it detects via iTunes / 3Utools.
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
Hi Ben,
Thank you for your valuable information. I will test it as soon as I have my new battery.
I will report the result then.
If it is indeed a Tristar problem, perhaps I'm going to give it a try to do it myself. I can solder but have no experience in micro-soldering, but at least I can give it a try.
Your information is very much appreciated.
Kind regards,
Stefan
さんによる
You will need a hot air station to replace Tristar, if you have soldering iron only you cant replace it as the solder balls are under the chip.
さんによる
Hi Ben, I will order a hot air station as it comes always in handy. It's going to be quite a challenge because I never did such a thing. I will order the Tristar as well. I will probably need it anyway so :) Thanks again for your help ;) Kind regards, Stefan
さんによる
Here is some good information on replacing the tristar chip:
iPhone 6S Tristar IC Replacement Tips
さんによる
Hi Ben, Thank you very much. It's a really good starting point. I will exercise first a bit on another device to see if I succeed in removing the components without pulling the pads beneath the chip.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Stefan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,109
