メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
147回答 すべてを表示
MacBook stuck in a boot loop
This is the 1st screen that shows up upon turning the laptop on.
This is the 2nd screen. This restarts the laptop and takes it back to the 1st screen.
This is the eventual last screen that shows until you turn the system off or restart it.
It seems the Operating System bricked during the last update after Yosemite.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
This link may help you out, it deals with the Mac reboot issue. How to address a constant reboot loop in OS X https://www.cnet.com/news/how-to-address...
Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You'll need to re-install your OS as something is corrupted.
Boot up in recovery mode (holding R key when you restart) that should allow you to start. But before you do anything you want to create a bootable USB thumb drive following this guide: How to create a bootable macOS Sierra installer drive or this guide if you have High Sierra: How to create a bootable macOS High Sierra installer drive
The reason you want the external OS installer is you'll need to do a complete wipe of the drive and re-format it. If you have anything important make a backup while you can before you do move forward.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh Marx さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,154
