メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
After cleaning PS4, PS4 still does produce loud sound and turns off
Hi i would got a problem. After cleaning my ps4, it still produce loud sounds and turns off by itself. I just open the backcover and remove the power supply. Using air duster to clean. Can anyone help me?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
19 件のコメント
Hi i need some help. When i turn on my ps4 and open any app : youtube or fortnite or anything the ps4 fan sound so loud like aireplane and still loud but did not turn off. I only play 10 min cuz im scared
さんによる
I just got this ps4 from my little cousin and it is doing the same thing accept it dont cut off just real loud like a plan and can feel the air I need to know what is going on I got my old ps4 pro the same one and if I could find someone to open that one up i can take the fan from that one and have it put in the one my cousin gave me. The other pa4 got corrupted and even after getting the new hard drive on there it was laghing and freezing why my cousin gave me this one but I think he gave me a boguess one that he knew was not no good and to me that is not cool at all
さんによる
Anyone know what to do if a deep cleaning,replace the heat sync,new fan and it still gets loud?
さんによる
My ps4 won't even show on my tv, i cant get it to go into safe mode now
I've taken my ps4 apart (and I mean apart), cleaned it and put it back as it was, still no good
Any help lads??
さんによる
There must be something to it, are you sure you put back all as it was ? Also try to bend the metal thing that has two thick screws bend it in the direction, so that it do more on the cpu. Also check any cable and ahhhh there is also a thing i thing it hast do with your hdmi port maybe or the cable is just broken though also when your ps4 does open try to go into remote play on your mobile phone and try do some settings idk let me know if any of these will help you.
さんによる
14件以上のコメントを表示
コメントを追加
14件の回答
ベストアンサー
Overheating on PS4's is pretty much never caused by bad thermal paste. You need to remove the motherboard and the bottom metal plate. That's where the heat sink is located. With it removed from the console you can clean both sides of it (you can only get to one side of it with the power supply removed). You'll probably find the side of the heat sink near the fan is covered with dust & debris. Give it a good cleaning and clean the fan while you're in there. When you put it back together apply new thermal paste to the APU. (Any time you remove the motherboard you should apply new thermal paste).
Hope this helps.
このアンサーは役に立ちましたか?
スコア 7
7 件のコメント:
This! When reading up on cleaning the PS4 fan, nearly everybody neglects to mention the heatsink. In my experience, this is equally important - if not more so - than cleaning the fan.
さんによる
I’ve just took mine to bits to clean it as it was saying it was getting too hot after playing it for a while, I put it back together without applying new heat sink and now when I turn it on, it starts normally but within around 45 seconds the fans starts going crazy speed, a message saying it’s too hot and then it turns off. I’ve ordered some heat sink and will strip it down again and reapply the heat sink. But would a lack of heat sink make it over heat within 45 seconds of turning it on?
さんによる
@strutbrace I'm assuming by "heat sink" you mean thermal paste. If so then yes, it will cause it to overheat if you don't re apply more when you put it back together.
さんによる
I have completed all of the above steps, and reapplied thermal paste, however my system has continued running high fan speeds and blue screen/shutting down. Any other suggestions? Seems like my system isn't actually getting hot, it's almost like it is an error that is turning off the ps4 immediately when the fan kicks on high
さんによる
I have alot of experience with this issue. But can't figure out what's going on. I have replaced the fan,did a super clean on every single part including the casing. Replaced the heat sink with the best stuff money can buy. But it still runs hot. It have never blue screened or turned off because of it that's why I'm confused as to why when the temp goes up it starts to get loud again. You know the point when you hear the fan and such kick in and you hear the sound go down mine just does not go down. It's not jet engine loud but louder than it should be by far
さんによる
2件以上のコメントを表示
コメントを追加
Does it go loud fan noise straight away when the PS4 turns on then shuts off?
Or does this happen after a while when playing games then fan ramps up then shuts off?
Usually what needs to be done is the PS4 needs to be cleaned of dust like you said and the thermal paste reapplied because it's common for PS4s to have bad thermal paste application from factory.
We've seen it many times when customers bring their PS4 in for the same issue at our repair shop.
このアンサーは役に立ちましたか?
スコア 2
11 件のコメント:
Yes. It happens during turning on of the PS4 then it turns off by itself. The loud sound seems like progressing. From no sound slowly gradually to very loud and finally it turns off.
さんによる
I agree, you should try reapplying thermal paste on the CPU of the PS4. Make sure to use good ones!
さんによる
My ps4 fan starts up slowly,then gets very loud,but doesn't shut off. I've cleaned my system of dust and my fan still blows hard. Why is that? Very unenjoyable
さんによる
Oh this only happens when I play a game,every game I try to play it blows hard to the point I can't hear my t.v......again very unenjoyable
さんによる
Need to strip the console apart to where you can remove the heatsink most of the dust gets stuck between one side of the heatsink and the fan plastic shroud.
Once that is cleaned changing the thermal paste and making sure all thermal pads are seated on well should fix the problem.
さんによる
6件以上のコメントを表示
コメントを追加
I had the same overheating problem,I changed the paste, but the real problem was the dust between the heat sink and the fan….After 5 years of daily usage,there was literally a wall of dust there,no wonder why my PS sounded like a fighter jet ready to roll out…After putting it back together, it's smooth and silent again,better than new…
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Well looks like I'm taking apart my system again to clean it AGAIN....this is bullshit! I've cleaned the dust out already and my fan still blows hard....like wtf
さんによる
Hi did u find a solution?
さんによる
コメントを追加
I have looked all over the internet for answers for months now, yes cleaning can help a bit, but the actual reason ps4 consoles are ramping up the fans on games like apex and fortnight is because of unlimited fps, it makes the cpu go nuts causing the fan to ramp up, until game developers change this, you u can clean dust change thermal paste buy thermal pads and you will just be disappointed that you have wasted money because this will not fix the issue, the problem is not the console, its the game and how its been set up by developers.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This ^^^ thats why its sum games but not others i try to play uncharted colection on ps4 pro 1080p boost on/no supersampling but with a clean fan and it gose nuts and over heats it fast to point i cant play any games till it cools yet i can run warframe on ultra settings supersampling full blown 4k @60fps with ease !! It defs comes down to game and how develpers optimizing them for both 4k and 1080p supersampling dnt hold ur breath tho with next gen down the road !! !!
さんによる
コメントを追加
Yes me to cleaned everything inside.
Also with new thermal paste .
I get the message too hot on
*Fortnite
*Conan Exiles
  • Call of Duty
  • but the strange thing is ****
GTA 5 is the only game where my ps4 is so quiet and relaxed ?? People who have this horrible problem with your PS4 PRO , try to play this game and see if we have the same issue. ( i have GTA 5 on disc ) .
My PS4 PRO is even LOUDER then before . Its not to do , and no fun playing anymore on the console.
For everybody in this forum , your Playstation is a part of your day, your life, we love all to spend hours on it.
And now we have a serious big problem with our console.
Lets hope we can find a solution for this.
Or hope somebody from SONY can help us to have fun and enjoy their Master piece they created.
SONY can also read on these forums where we try to repair our Playstation that is broken .
But nobody ever place a reaction what the problem is or can be.
For my opinion, I’m very disappointed they don’t help us, We are also people they earn money from every day.
I hope it’s gonna change, and that SONY step up for the people they lost their warranty.
Or they recommend you to buy a new console in the worst case. Then we know the mentality from SONY
I think they still want us to stay with Playstation! ;)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Cleaned my ps4 and it's still overheating
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Is it a must to add new thermal paste can I just clean and put back together.
さんによる
Definitely need new thermal paste. It's like $7 for a tube of good stuff, just do it.
さんによる
コメントを追加
I did all the recommended suggestions cleaned all dust new thermal past. Ps4 is blowing cool air it's just the fan is loud.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same as my pro took it all apart got rid of all the dust new thermal paste it blows cool air but the fan is at max speed
さんによる
コメントを追加
So I cleaned it out removed the heatsink and everything, also applied new thermal paste any clue why my ps4 is still giving the too hot message and turning off?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the issues of the super loud fan and finally while playing Warframe it shut off due to overheating on 4/16/2020
I dust my PS4 Pro once a month so I I just took off the top cover and kept playing because everything was closed.
Yesterday we took it apart and replaced the thermal paste and dusted the heatsink and cleaned everything else. Tested it on Modern Warfare and Red Dead 2 for 3 hours straight and it's been quite ever since to the point I played Warframe for 5 hours straight today and it is was still blowing cool air on a low fan speed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’ve cleaned all the dust and replaced the thermal paste but my ps4 still sounds like a jet. How can I fix this?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Literally same
さんによる
コメントを追加
The only way is clean all throughly, and change the paste and clean all dust, it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had a similar issue after I replaced the optical drive. The system would immediately go into overheat mode when a game was loading. Streaming services and whatnot were fine, but nothing processor-heavy would work.
I applied some arctic silver grease, which may have helped, but I think the orientation of the X bracket that clamps down was upside-down. It seems like the tiny nub in the center should face down to push down on the component below it, but it should actually face upwards.
If you’re experiencing the same issue, check the orientation of that piece. It may fix your issue.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I just cleaned my ps4 taking everything apart piece by piece and when I put it back together the ps4 ram quiet after like 40 seconds and then it starts getting louder and then I go into a game and as the game is loading it gets Luger and louder and the fan is spinning so fast and loud the PlayStation doesn’t even feel warm but it says it was to hot and then I shut it off because I didn’t know what was gonna happen what do I do to fix this?
さんによる
コメントを追加
I just cleaned my PS4 and as I was cleaning the motherboard a little foam piece fell off and I didn’t think much of it. Now when I turn on PS4 and load up a game it instantly shuts off. I just want to know if the foam piece is the problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tbh I just cleaned my pa4 and only cleaned the fan and heat sink with cutips, and needle to take out lint, I will tell you it doesn’t make any sound anymore AT ALL!!(: and I have cats so believe me when I say that $@$* was dirty af with hair and dust that covered up the heat sink on both sides! And burnt hair at that it was all hard and looks blackish, my wife even told me I should’ve recorded or took pictures of it for reference but I was so focused on the cleaning, and even now she calls on me because she used to be able to hear the ps4 in the next room when I would play for hours (x doesn’t even get the slightest of hot and I can actually feel the cold air on the side of the ps4 from the fan, hope this helps I had only removed the metal plate above the fan and heat sink to clean it so just in case anyone is afraid of breaking anything the way I was you don’t have to take it off to detail as much, Hope this helps, it really helped mine,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
James Renato さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 32
過去 30 日: 136
今までの合計 109,892
