メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Apple logo keeps flashing on and off
Apple logo keeps flashing on and off when trying to power on
held down the power button and home button for 10 seconds
itunes logo comes on for me to connect to itunes
connected to itunes for update and/or restore
error comes up when doing the update
error code 9
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
An Error 9 message on an iPhone 6 can be a lot of things but pretty much all of them require highly advanced repairs. The immediate DIY thing to try is to use different and known good cables and computers. Once that is ruled out, you can try different software tools, such as 3uTools but I suspect you will get the same problem.
One thing you could try is to apply pressure on the CPU with your thumb while it is booting. If that works, then you will need to find someone who has mastered the Error 9/CPU Grind repair. Otherwise it could be a NAND issue which would require a reballing and reprogramming to fix data corruption. It could also be Tristar related but usually it is NAND/CPU.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Nathan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,198
