Problem with charging in Galaxy S8+
I have a feeling that the charger does not connect properly to the micro usb port. It is loose and often disconect. Phone is out of warranty. CAn I repair it myself? Do you know if I have to solder new port? How much does it cost in workshop?
この質問は役に立ちましたか?
4 件のコメント
Try cleaning the port first i had a similar problem so i took a toothpick trimed it down and use it to clean out the dust in the port then my phone started charging again, be careful not to damage the port when doing this,
O s さんによる
It works, I just can't turn it sideways, any suggestions?
Kayleigh Harkenreader さんによる
Definitely, clean it carefully with a toothpick broken in half such that it breaks diagonally and is thinner and pointier. There was so much lint and gunk in there... packed in tight from the connector going in an out for years, took about an hour to get it all out.
gunslingor gunslingorsadf さんによる
The Tooth Pick method worked. Here are some detailed instructions.
1. Fashioning a Tool: Use a box cutter / utility knife and whittle / shave the toothpick till one end is flatter and thinner with an approximate rectangular cross section.
2. Problem Area: Looking into the phone's connector slot, you will see a thin tab surrounded by empty space. This tab has connectors on both it's faces enabling either way plugging of the cord. The problematic Lint is caked-on on these 2 faces.
3. Action needed: Use this thin, slightly bendy end and lightly rub around the 2 faces of the central tab. Go deep into the empty space, apply light pressure on the face and scrape outwards.
I was surprised how much lint came out.
Don Dil さんによる
