メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
How to stop iOS update to the latest version notification?
Apple does really disturb me when my iPhone pops up notification to upgrade to the latest iOS. It said that iOS 11 is not so good to the elder devices, I use an iPhone 6 and it works good as for now, I do not get used to upgrade, apps or system. If there's any way that can stop iOS nagging me to update to the latest version? Thanks for any help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
That pop up isn't the iOS update pop up, it's the carrier settings update.
さんによる
Doesn’t work. It deletes it but it comes back in a few days. Eventually it stops for maybe a month. But then comes back again, despite my automatic updates being supposedly disabled. I’ve had the slider to off for almost a year, and I’ve deleted update pushes form apple about 40 or 50 times. This is an old “fix” and is only temporary. I’ve deleted the iOS 12 update 4 times in the last week, alone, despite doing this “fix” last winter.
さんによる
コメントを追加
3件の回答
ベストアンサー
Trying to be careful as my answer was marked as spam. you can find the profile (Beta Profiles) Block Update for IOS online. Download the profile and follow instructions. I used it on iOS 14.2 and it removed the notification and blocked iOS 14.3 from downloading.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
I find the iOS update queries very disruptive as well however what you are showing us is a Carrier update, which I highly recommend you do. It will not affect or change your iOS.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
You may not have read my question, the screenshot is just a screenshot, I've chenged to another screenshot which can show the problem, but it is an iOS 9.0 update notification, I got it online, just for reference. Do not be so aggressive. I appreciate your quick reply, thanks anyway!
さんによる
コメントを追加
This is the best way I can think of.
1. Open the Settings app and go to “General”
2. Choose “Storage & iCloud Usage”
3. Go to “Manage Storage”
4. Locate the iOS software update that is nagging you and tap on it
5. Tap on “Delete Update” and confirm that you want to delete the update*
This deletes the available iOS update which stops the iOS update from popping up every day, however, the moment you’re on a sustained wi-fi connection for a while the iOS update will download itself again automatically and start sending pop-ups to install it again. If this happens, just redo the steps.
You won’t lose the ability to install the iOS update, you can download it again yourself by going to Settings > Software Update, or just join wi-fi and leave the device unattended and it will download automatically without prompting.
I hope this helps!
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Than you, Leo, your answer seems promising, I'll try it out.
さんによる
Keep me updated!
さんによる
Really helpful, thank you!
さんによる
コメントを追加
回答を追加する
Albert さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 13
今までの合計 5,881
