メインコンテンツにスキップ
LGによって製造されたラップトップモデルの修理ならびにサポートマニュアル。
23回答 すべてを表示
Why is my laptop display split into 3 sections?
My laptop screen split into 3 sections, the right section appears to the left and the left appears to the right, the center remains in the center but keyed out!
This is a picture taken from my laptop
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
10 件のコメント
Hi @ejdr ,
Try starting the laptop in safe mode and see if the problem is still there.
If it works OK then perhaps it is a driver issue.
Stupid thought but can you "drag" (click and hold while moving) the right side of the screen back to its' proper position on the left?
さんによる
No it cant move
さんによる
But sometimes it goes back to normal. Is it possible that its the display assembly?
さんによる
Var der nogen løsning? for jeg har samme problem.
さんによる
Hi.My laptop is doing the same too,It's splitting into four sections with a poor quality and a black line crossed between the 2 sides of right and 2 sides of left
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
選択されたソリューション
@ejdr it will help if you let us know the exact model of your laptop. Also, even so your description is good, it might help if you post some images of t\what your screen shows. Use this guide for that. iFixitでの質問に画像を追加する方法 It will allow us to see what you see. Connect an external monitor to your laptop and see if that displays right. If it does then you probably have an issue with the driver board of your panel. This would require a display replacement (y first suspicion). If it doesn't display properly it could be a GPU issue (motherboard) or a driver issue. Depending on your OS you may consider a driver update for your video card (GPU)
このアンサーは役に立ちましたか?
スコア 2
14 件のコメント:
When I connect it to a monitor it shows good but in my laptop it splits in 3 sections
さんによる
Okay, sounds like a bad LCD. You will see there there is a circuit board that is directly connected to your LCD and it is really not replaceable. It is on that board that you have a component failure.
さんによる
@oldturkey03 what is the possible solution for this?
さんによる
can I fix it?
さんによる
Only repair for that is the replacement of the display
さんによる
9件以上のコメントを表示
コメントを追加
I still have an old Toshiba laptop that I don't use much anymore that was having the exact same problem. I plugged in a VGA cord to a projector and both screens are working correctly after that. I also freed up the right hinge that had come disconnected from the base by breaking some plastic away from it. There is a wire that goes through there, maybe it was kinked or half broke because the hinge isn't in the right spot. I did both of these things at the same time, so I don't know which one fixed it, but I suspect it was plugging in the VGA cord to an external video display.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Elvin さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 19
過去 30 日: 94
今までの合計 6,347
