メインコンテンツにスキップ
Repair guides for feature cell phones manufactured by ALCATEL. This category is for phones not using an Android or Windows operating system.
63回答 すべてを表示
Alcatel Onetouch start pinging and flashing - no alarm, call or text?
Phone pings and flashes completely and bizzarly out of the blue - no alarm set, no calls coming through and no texts? It was water damaged over a month ago and dried out in bag of rice. Any advice welcome.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @pennycatkins ,
Rice is good to eat but does not fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Because the phone was not opened and cleaned and dried properly after it got wet the corrosion has continued and is now starting to cause problems.
Turn off the phone and do not continue to use it. You also need to remove the battery to prevent further damage occurring.
You then need to further dis-assemble the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain scents and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
You do not state the model variant of your Alcatel One Touch, (Snap, Idol, Pop, Pixi etc) so you may have to search on YouTube to see if there are any teardown guides for your particular model, that may help you to open the phone to disconnect and remove the battery and also then to clean it properly.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 285
