メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1137/1、2、4GB容量/カラーオプションはブラックとホワイト
Simpler battery replacement process?
Could the process shown at iPod Nano 初代のバッテリーの交換 be simplified at step 7 by simply cutting and stripping the wires and soldering new battery wires together and covering with heat shrink tubing? This would remove the requirement to disassemble the logic board, thumbwheel and front face of the iPod nano.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
That's a little too ghetto for iFixit.
The whole point of that guide is to remove the logic board so you're not messing with any of the other components while using the soldering iron. iFixit presented the safest option. I wouldn't recommend that people follow your advise (even though it sounds feasible) just because it's kinda of jerry-rigged.
If you want to take a step further, you could technically just follow the soldering steps without removing the board. I do NOT recommend that. There's no reason to use heat shrink tubing at all.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
dont know if its the battery how do I identify the problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
matthew, it would work great for you if you post your own question. Click on the link on the right side of the screen "Ask a question" and give as much detail as possible. Like what device, what problem. has it just happened, anything you were doing just prior to? Need more info than the one sentence you posted as an answer to someone elses question ;-)
さんによる
コメントを追加
回答を追加する
fredvandenhout さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,004
