certain keys wont respond
Letters and numbers such as (8, i, k,) wont apear on the screen when I press on them , what do i do ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Salma Repole
Try following this step below to dismantle your keyboard
Asus Chromebook C201 Keyboard Replacement
there is a lvds cable which is connected to the mainboard. Disconnect it carefully and clean up your keyboard.
Use an eraser to rub on the LVDS cable connector of the keyboard module and reconnect it back.
Test your keyboard, one good link to test and spam the keys...
http://www.keyboardtester.com/
Launch It and test...
If all fails, consider getting a replacement keyboard module from ebay.
このアンサーは役に立ちましたか?
Hi,
Here are some possible fix -
Hope these steps will help you to make your keyboard working properly.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 2,398
