メインコンテンツにスキップ
A single-serve blender made by Hamilton Beach in 2011. Similar to the Hamilton Beach 55103, 51126, 51131, 51132, and 51133.
9回答 すべてを表示
I brought this blender and it will NOT START!
I plugged it up to every kitchen circuit in the house, but it will not turn on. I'm not sure what is the problem or how to fix it, Please help! (yes i push the power button when it is plugged in, but it will not start!)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Some blenders will not start without liquid in them, to prevent burning out the motor.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
For my 51101B blender, the whole blade assembly popped out, so the blended liquid leaks from.the bottom like a water falls. how to fix this?
さんによる
コメントを追加
You say every kitchen circuit...have you tried it in an outlet that you know is live, that is all that really matters. Like, do you have a toaster or something that is working? Then use that same outlet. Kitchen outlets are required to be GFCI protected and so if one outlet gets tripped, either by a quirky appliance or a power surge or storm, ALL the outlets that are wired along with that GFCI device will be affected...even if that particular outlet is just a normal looking outlet. If it does not work even with a known good outlet, then you can move on to possible physical problems with the blender. Could be a bad power switch: Hamilton Beach 51101BA Power Button Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joy Best さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 75
今までの合計 6,450
