@benlogali9 the UL code is for Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
There are a few things that can cause this. Check the suspension kit of the drum to make sure that it is not excessively loose. Most commonly for this model is a failed rotor position sensor or a cracked stator on the motor. To check that, you will have to check the bottom on your washer. Make sure that the motor bolt is tight
The following images show how to get to those two parts.
You do want to consider posting some images with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. It will allow us to see what you see.
4 件のコメント
My washer does that Ul code at the final spin the entire bucket moves uncontrollable the the ul codes appears
Julie Cruz さんによる
@Julie Cruz
What is the model number of the washer?
Bucket moving about might be a problem with the suspension rods.
knowing the full model number will help to find the correct part if they are faulty/broken etc.
jayeff さんによる
Maytagz quiet series bravos 300
Lee Hart さんによる
@Lee Hart
if it is the suspension rods that are the problem, knowing the model number will ensure that the correct parts are listed in an answer.
jayeff さんによる
