メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
Do it yourself TarDisk?
A few years ago, I added a 256 MicroSD card with an eBay adapter to my MBA SD port and I wasn't impressed. It was incredibly slow and I was constantly getting the beach ball. Now I'm hearing about these TarDisks and I'm wondering how much of it marketing hype.
Even at UHS‑I speeds, $400 for a 256GB SD card, is highway robbery. Is there a do it yourself solution that's comparable to TarDisk? The software just joins two partitions together, right?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
If you are just looking for storage the Tar Disk is not for you. Get a 200GB SD card like this for $40.00
Card technology had improved performance dramatically.
https://www.amazon.com/MiniDrive-Air-Ada...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@mayer has more experience with TarDisk drives. Maybe he has some words of wisdom here.
I'm afraid I'm a bit of a stick suck in the mud ;-}
I was never impressed with these adapters to replace the custom Apple SSD's. We did some tests a few years ago to see how good they where. We found many drives had a very high count of CRC errors. Which overtime would wear out the drive prematurely and could lead to data loss.
I would stick with either Transcend or OWC replacement drives or just find a used Apple drive. Sorry to say they are a more costly solution.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Are you just using it for storage or are you wanting to set up a fusion drive?
さんによる
Storage. 12 characters
さんによる
コメントを追加
回答を追加する
applerepairshop さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 180
