メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Black screen even after screen replacement and iOS repair
Hello,
My screen went black while video chatting on google hangouts. The sound continued to work through the call and when plugging in/using the vibrate switch. I let the phone die and tried plugging it back in to charge with no luck. My home button had previously stopped working and I was using the accessibility function to unlock before this happened, so I couldn't hard restart the phone. After some time I tried replacing the home button so I could perform the hard restart with no luck. I then tried to replace the LCD screen (including new camera, home button, etc). And have still had no luck. I tried replacing the firmware in an irepair software, and have now tried factory reset through the program and have successfully seen the phone get wiped (which has really defeated the purpose of me trying to fix it because I only wanted the data off but since the screen doesn't work I couldn't retrieve anything). I was hoping a factory reset would help and I could restore from an older backup and at least get some files back. iTunes recognizes the phone, I see nothing on it, the software has been updated successfully, but the screen remains black. The sounds still work as always. Is there anything else I can do or is this beyon DIY repairs? I live overseas and although there is an Apple store nearby I'm not sure it will help as this is a US phone, and it's way beyond warranty anyway.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Sounds like a backlight issue, needs a board level repair as a chip has blown.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try looking at the screen with a flashlight up to it. If you can see the screen with the flashlight, it is definitely a backlight issue. and will need board level repair
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Somehow? .I am not really sure about using the flashlight to solve this issue.
さんによる
I think a replacement of new board is better or just repairing depending on you .
さんによる
コメントを追加
回答を追加する
Heather Staples さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 57
