メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleアシスタントを搭載した音声起動型スピーカー「Google Home」の小型版。2017年10月4日に発表され、2017年10月19日に世界中で発売されました。
Why it's not wireless anymore?
It only powers on if it's plugged in to the charger. It use be a rechargeable device.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
After doing some research I can conclude the following,
According to few forums and google support, the Home Mini does not have a integrated battery and only works using the 5V 1.8A adapter.
None of the Google Home products feature this anyway (Which does make me wonder why you'd think it was rechargeable before)
So basically, sorry but no it does not have a rechargeable battery.
HOWEVER, the Google Home (standart, not mini) has an option to get a "portable battery base", which gives 8 hours of use (Info found here: https://www.cnet.com/news/add-a-portable... )
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
The power consumption of the Home Mini (= GHM) is averaging 0.25A at moderate volume (50%).
On a power bank with a sufficiently large housing like Tomo V4 (bought at banggood.com), the GHM can be carried well through the house. The micro USB connector shell must be small enough to fit into the recess on the housing of the GHM. (!)
I have equippet the Tomo V4 with 4 lithium-ion batteries (NCR18650B, 3400mAh). It has powered the GHM at its 2 amp output almost daily for over 4 months. I am using a magnetic charging cable, which can be easily connected during operation of the GHM without mechanically stressing the micro USB socket of the power bank's charging input. The Tomo V4 can't bei charged in parallel, but further unloading is prevented.
Are about 24 hours of "wireless" operation on a power bank with "24 Ah capacity" sufficient?
さんによる
コメントを追加
回答を追加する
Emiliano さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 620
