Why is my washer flashing dr then F?
My washer will not start, it has a rhythmic buzz and then it starts flashing the error code.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The "dr" code means the control panel doesn't recognize the door is shut, so it will not start. Check the door carefully to see if it is shutting fully, and also check for damage to the door strike plate. If all looks well, then you will need to replace the door lock assembly.
Go to https://www.searspartsdirect.com/, and type in your specific model number to find the part.
Here is a guide for replacing the door lock assembly: https://www.searspartsdirect.com/repair-...
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 27
今までの合計 1,696
