メインコンテンツにスキップ
An HP desktop computer released in 2008.
12回答 すべてを表示
Why my computer when start has many tat tat sounds and not working is
HP dest top computer
Update (04/16/2018)
Can my desttop the ram problem ? the mouse arrow got stuck and I pressed power button half way a min, shutdown desttop computer restart got problem already window 7 not start property!..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Hi @kkchan02 ,
Try using the HP SMART. HDD diagnostic software found in the BIOS setup area, to test if the HDD is OK.
As @slagle stated it sounds as though the HDD is failing or has failed.
If it has failed, you cannot repair it, you can only replace it. Hopefully you have backups of your data.
Update (04/16/2018)
Hi @kkchan02 ,
Have you done the diagnostics on the HDD? You haven't said. You really should try it
Download this (select Ver. 7.5 Windows Free Edition) to a USB and boot the PC from the USB to test RAM. If PC boots OK and tests pass then RAM is not the problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I think it might be the hard drive might be having a Read and write head crash problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No not solved, the mouse arrow not moving got stuck...so I pressed the power off button half way wait for half miniute ,PC start shutdown, when re-start computer not working asking to press F1 key etc,later PC still cannot boot up and I again press power key half way for a while PC shutdown ,later I again pressed the power start button , this "Tat tat" sounds came out ....any guru can give idea how to repair it...?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
chan k k さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 30
今までの合計 157
