メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 Poor Wi-Fi Connection
My iPhone 6 started having a really poor Wi-Fi range. I have to be close to router to connect, and it sometimes disconnects when standing just next to the router. And the connection is really slow.
It reconnects after a few minutes.
Some say I should change the antenna, some say I should only change the flex cable.
What should I change?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
The front camera and ear speaker share the same flex, so it's normal that both could fail at the same time. The WiFi antenna is in the same area but not physically part of the same flex. It's actually in the housing instead of embedded within the screen assembly. Did something happen to the phone recently, such as a heavy drop, a repair or contact with water? Those are the kinds of events that could cause multiple problems.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
There is an inter connected antenna on the underside of the board that may need to be reseated. Unless you are extremely diligent with the screw and all of the small parts I would suggest getting some help with the repair.
If this doesn’t solve the issue there is also microsoldering options but we can cross the bridge on that after the antenna is checked.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
You mean to reseat the antenna. Not replace it? Can you please refer me to the guide.
さんによる
here: iPhone 6 Wi-Fi アンテナ交換 it says replacement, but you can use this guide to get to the part.
さんによる
コメントを追加
Like Scott says replacing the wifi antenna is your first option ,it's common for this part to fail and cause weak wifi.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
AaAa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 195
