My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface 充電ポートの交換 or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface バッテリーパックの交換
ガイド
難易度:
中レベル
5 - 10 minutes
ガイド
難易度:
中レベル
15 - 30 minutes
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 14
今までの合計 25,469
1件のコメント
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
Gil Cancela さんによる
