メインコンテンツにスキップ
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203回答 すべてを表示
UN65EH6000FXZA YH02 strobe backlights
UN65EH6000FXZA YH02
I have a Samsung UN65EH6000FXZA YH02. The backlights strobe I get no sound no standby light or noise. I have replaced the main power board and get the same thing. When I disconnect the control and tcon board and just have thebacklights connected I get the strobing backlights still. But when I disconnect the back light and just have the control and tcon board connected to the board I get the standby light and it makes the start up noise. Do anybody have an i dea what is causing this and the part number i would need to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
jaded past "When I disconnect the control and tcon board and just have thebacklights connected I get the strobing backlights still." sounds like a failed backlight array or a bad power board. Post some images of all of your boards so that we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that. You can measure the voltage on the led connector to see if the "strobe" originates there. If not then you know it is most likely the array.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How would I measure the voltage I honestly have never done that before. Tv powered on or off? Give me the steps and I can get it done and post my results. And again that is a brand new power board.
さんによる
コメントを追加
回答を追加する
jaded past さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 211
