メインコンテンツにスキップ
Troubleshooting and Repair for the 32" 1080P LG 32CS560 LCD TV.
47回答 すべてを表示
Screen went suddenly black. Sound and backlight are working.
I have the LGCS560 TV and the screen went suddenly black.
The backlight and the sound are still working. I tried to turn on and off but it keeps doing the problem.
It looks like LG has scheduled a Planned obsolescence.
Government should start to do something about it, these companies are screwing all of us and the environment.
The TV is perfect and I'm sure it will cost a lot to repair it so they force us to throw it out and buy a new one!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Pietro Zucca could be the display but you do want to check the T-con board and the main board first. Unplug your set, remove the back and check all the boards. take some pictures and post those with your question so we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
Update (04/07/2018)
Pietro Zucca use your multimeter and check the power-on sequence as directed. Let us know what you find
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, I've added the picture :D
さんによる
Pietro Zucca great thanks for doing that. Do you have a multimeter to measure some of the components. I'd stat at the T-con board and see if it gets power....let us know how comfortable you are doing this and if you have a meter and some experience.
さんによる
コメントを追加
It's not the obsolescence that screwed it over, that only makes it !&&* to buy an obsolete product, but you already have one.
It's probably the display, there are quite a few on EBay.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pietro Zucca さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 204
