Cellular network not detected and invalid sim card
I bought phone because is was compatible with Sprint it's saying sim locked and network not found
Did you put in a unlocked or locked sim card cause that can matter. Check your carrier to make sure you are using their correct sim card designed for unlocked phone.
このアンサーは役に立ちましたか?
How do u get the Sim card unlock code for metro phone
Well it is not a code but a completely separate sim card designed for unlocked phones. Most likely you will need to switch plans but talk to your carrier as I do not know how metro manages their plans. You will need a GSM sim card to be able to use this BLU phone and any other unlocked phone. By the looks of it I think you are on a plan that will most likely charge you a hefty fee changing from a locked phone to an unlocked phone but still talk to your carrier and make sure about this situation before you throw a bunch of money away.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 3,502
