Where is the Speed Control Located?
where is the speed Control located in the Nissan Altima 2.5 2002?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Do you mean the Engine Speed Sensor? This is located on the back of the engine block near the transmission. It is held in by a 10mm bolt.
このアンサーは役に立ちましたか?
Having a problem with my 06 Altima I'm driving around 70 mph and the rpm won't change it just keeps going up so the transmission not changing gears could the transmission speed sensor be no good or do you think the transmission no good anymore please need help thanks
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 3,711
