メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2010年8月発売。部品番号:884354009250。
Why are my files missing from the H1 Zoom interface but present on SD?
Hi,
So I am using the H1 Zoom to record interviews that I am carrying out as part of a research project. I've conducted 3 interviews so far and will be conducting many more in the coming weeks and months. As I record each new interview, I just hit record and the file becomes file 2 thentthe next becomes file 3 and so on.
Last night when up loading interview number three to my laptop I decided to changed the file names to something more identifiable.
Today, when I went to play back the last night's interview on the H1 Zoom, it was no longer there. In fact, none of the files were.
The strange thing is that when I plug the H1 Zoom into my laptop via USB and go to view files, they are still there with the new names I gave them!
So I'm at a loss to understand what exactly has happened and while I haven't lost anything, I'd still like to know what I did or what happened.
Also, while here. I'm recording on MP3 so far at 128. I'm not overly concerned about sound quality, just need it to be clearly audible for the purpose of transcribing. Is this an okay setting?
Another thing that mystifies me is that the time remaining never seems to change and stays at 99:99:59 at all bit rates with the exception of 48 where it is less?
Thanks in advance for help forthcoming. As I'm sure is evident, I am very much an amateur in the area of sound recording.
Joe.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi Joe,
My guess is that the H1 only recognizes files with a specific filename format. When you renamed the files, the Handy no longer recognizes the files as ones that it recorded and thus ignores them.
I think 128Kbps MP3 is sufficient for transcription purposes. It is always good to listen and check.
Depending on what memory card you put into the H1, it can record a very long time. For example, if you have a 8GB card, the specifications say you can record ~139 hours using the 128Kbps MP3 setting. The time meter can't show that much, so it pegs at 99:99:59.
When you cycle to "48", you may actually be entering the uncompressed "WAV" format. This format uses significantly more memory so the H1 will show reduced recording capacity.
Hope that helps!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi Arthur,
Yes that's really very helpful and explains a lot!
It makes sense that changing the file name would affect the recorder's ability to recognize the file.
I have re-listened to the files that I have recorded at 128 so far and they appear to be fine. I may up it to improve the sound quality slightly.
Thanks for taking the time to answer. I really appreciate it.
Joe.
さんによる
コメントを追加
Clearly the unit was not designed with such futuristic card sizes in mind. I know this is five years later. But maybe other people will pick up a second hand H1 and have the same question!
I was also mystified when a 32 GB card gave rise to "99 hours" across the board - except for at 56 kbps where the time seemed to decrease!
So I had this:
44kbps = 99hrs
56kbps = 71hrs
64 kbps = 99hrs
80 kbps = 99hrs.
I thought it must be some sort of bug. After much investigating I think I solved it. It's a combination of two things - the first one being sort of obvious, but the second one being a bit obscure.
1) Obviously it can't display more than 99 hours. Anything calculated to be 100 hours or more gets capped and stated to be 99 hours 59 mins 59 seconds.
2) But the recorder also appears incapable of even calculating numbers greater than 999 hours. So behind the scenes, once it reaches 1000 hours it loops back around to 0! So you could have 1001 hours of recording time available and the unit would report just 1 hour available!
So the actual hours for my example, calculated myself are;
44kbps = 918hrs = capped at 99
56kbps = 1071hrs = 071 = 71 hours (it dropped the 1000!)
64 kbps = 1530hrs = 530 = capped at 99 (so it dropped the 1000, but doesn't change the end result).
80 kbps = 1836hrs = 836 = capped at 99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Whelan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 40
今までの合計 2,526
