メインコンテンツにスキップ
How do I install new bluetooth antenna
I have a new bluetooth board and that is easy to install but they unfortunately did not install the antenna at the factory?? So how do I install a new antenna (which can be purchased easily on e-bay) or more precisely where do I route the antenna and where do I attach the other end?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
The bluetooth antenna is probably hiding in the corner. Here's the installation guide: iMac G5 20" Model A1076 Bluetooth board Replacement
See step 4 and look in the corner to the lower left of the card, it may be tucked under.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Kevin,
Every 20-inch iMac G5 I've been in has already had the cable. Did you pull out the power supply to make sure it wasn't tucked away somewhere it shouldn't be? Do a double take before trying to follow these instructions:
http://www.appleselfrepair.info/imac-g5-...
I didn't see a guide for this on iFixit but found that guide via google.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kevin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,754
