メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Mac won't start + Dim green light on magsafe charger
I have the dim light problem with my Macbook pro. The laptop received liquid spill a while ago (half a year) but it seem to work just fine until last week, when I tried to plug in the charger and all of a sudden the laptop shut down and I haven't been able to boot it.
I have tried:
1) Using another charger (still get the dim light)
2) Resetting the SMC
3) Replacing the battery
4) Removing battery from motherboard and plug charger to see if the laptop reboots (it didn't).
5) I have checked for corrosion in the motherboard and can't seem to find anything. The touchpad does have corrosion but not the motherboard.
Any thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
What was the liquid and where did it enter. When you opened it up, did you see corrosion (especially on the mag-safe board?
さんによる
The liquid was rain and it entered via the keyboard. I did not see corrosion, and I didn't see corrosion in the mag-safe board (just a bit rusty because of the age).
さんによる
コメントを追加
1 件の回答
最も参考になった回答
If any rain got into the keyboard the back side of the logic board might have gotten wet. Sorry to say rain water is acidic and not that clean (air pollution).
As you can see, there's more stuff on the backside of the logic board:
Follow this IFIXIT guide: MacBook Pro 15" Unibody Mid 2010 ロジックボードの交換 and then compare the image to your system board do you see any components that are burn't or damaged?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ramon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 232
