メインコンテンツにスキップ
Repair guides and support for motorcycles manufactured by Honda.
75回答 すべてを表示
Reverse flashing and no cruise
2003 GL1800 no new work has been done. Converted to trike in 2004.
Cruse control would not engage. then noticed the reverse light was flashing. no cruse and no reverse, but otherwise runs great. any ideas???
Looks like the only "common" component is the CRUISE REVERSE CONTROL MODULE, but is there any other item in common? Are the fuses and/or relays used for seperate systems? So it seems like each fuse and/or relay is not common to both systems. Or is my logic wrong? Ron . xhockybro@aol.com
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Go here someone has the same problem as you. The guys on the forum help him through it. Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ronaldo H さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 129
