Broken back glass and charging port
Where can i get oem adhesive
, Glass and charging port for unlocked note 8? And did they use uv glue? Acrilic or eco? I would like to maintain as much water resistance as possible assuming i dont mess it up getting to the port. And do i need to replace the camera \ print reader glass \ adhesive? And should i remove all old adhesive? Or leave it in?
2 件のコメント
Thank you for the explanation now if i could figure out what type of glue was used and if there are any precut pieces covering all needed areas or i just wing it or use 1 solid piece covering whole back w cut outs for sensors? The barametric preasure test was really helpful and have just the device to test it in.
Patrick F Mclendon さんによる
You can get the oem adhesive here.
Mandy さんによる
