Device not switching on.
My device is not switching on , instead it is tripping power.
@dinnesc make sure that your device is an LG 32CS560. If it is tripping the fuse you obviously have a short circuit on one of the board, most likely the power board. Unplug your set and remove the back. then take a good look at the power board and see if you can find some obviously damaged components. Post some images of your boards with your question so that we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
